주요 콘텐츠로 건너뛰기
The PowerShot S110 has a 12.1 Megapixel High-Sensitivity CMOS sensor and DIGIC 5 Image Processor, 12-bit multi aspect RAW+JPEG, 24mm Wide-Angle, f/2.0 lens with 5x Optical Zoom and a sleek pocket-sized body.
6 질문 전체 보기
Why does the display keep saying there is a lens error?
You will be unable to take any photos if have a lens error display from the camera.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 6
댓글 달기
답변 1개
가장 유용한 답변
If you are getting a lens error, it could be one of four things. There is dirt in the connection between the gears of the lens that needs to be cleaned out, the focusing motor is inoperable and needs to be replaced, the lens extension gears have been damaged and need to be repaired/or replaced, or the lens was previously obstructed from extending by an external source and needs to be cycled off and on. See Troubleshooting page and replacement guides.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
There are definitely more than four things for this error. Mine was caused by a broken ribbon cable inside the lens. It got worn down by lens movement.
can someone post a good Repair shop in the North East!
댓글 달기
귀하의 답변을 추가하세요
Pierre 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 17
전체 시간: 3,797
