이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 1개
John Smith, your "USB control IC" is U2 on the logic board. Check this video. It is a BGA IC and as such requires a rework station, the right stencils, plenty of flux, the right temerature profile, and the right solder balls. If you have never done this before and if you do not have the right equipment, do not even try this. The cost for the equipment alone will be more than if you send your phone of to get it repaired. Even for the pro's, this is a very difficult IC to replace
댓글 1개
oldturkey03 의
