주요 콘텐츠로 건너뛰기
Not enough disk space? Need a backup solution? External drives provide you with extra storage in your office or on the go. Learn how to repair them here.
334 질문 전체 보기
질문 마감됨
External hard drive won't power on or show up in disk utility
Noob question: I've plugged my new 500GB hard drive into the external silicone case and plugged the attached USB cable into my mac. I would like to format it but it does not appear on may Macbook Pro.
The hard drive makes no noise and it does not show up in disk utility or in finder etc.
I did notice there was no power connector inside the silicone case. Is there a connector missing? - see pic below.
Thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
Try changing USB ports.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
The larger connector is the power connector and the smaller one next to it is for the data. Does the drive work on or in another computer when not using the external case?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Mayer is right. Can I see the Sata connection again? You cut it off the second half of the pic
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 487
