5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2994 질문 전체 보기
Wife is upset because her phone is stuck in speakerphone mode
A few days ago I replaced the speaker in my wife's iPhone because it wasn't working. Since then, any phone calls and facetime calls can only be done in speakerphone mode. when you try to turn off the speakerphone nothing happens. It's in a constant state of "unable to make a private phone call" as I have come to call it. Any suggestions are greatly appreciated.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글:
Thanks for all the great answers, especially yours Mayer I'm definitely taking that advice to heart LOL! After careful inspection what I found was that the ground prong on the speaker assembly at the logic board was bent when I installed it and not hitting the case. As soon as I rectified that the phone works fine. I had actually skipped a few steps trying to hurry and didn't pay attention to that so take note everyone.
의 답변
의견 추가하세요
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
3개의 답변
선택된 해법
Never repair anything for your wife, have a professional do it (even if you do it, tell her a professional did it). Years later, after it has worked well you can fess up, meanwhile you don't have to take her abuse.
해당 답변은 도움이 되었습니까?
점수 1
댓글:
Haha I literally LOLed - good word of advice :)
의 답변
의견 추가하세요
가장 유용한 답변
Go to settings, accessibility, call audio routing
Let us know if that was the issue!
해당 답변은 도움이 되었습니까?
점수 4
댓글:
Although this did not happen to be the issue with Chris's phone it was with mine (an iPhone 5SE that was defaulting to speaker with every call). The one modification I would add is that the sequence of key commands is settings>>general>>accessibility>>call audio routing. Sure enough, when I followed your excellent advice my call audio routing was set to "speaker." I switched it to "automatic," made a test call, and rejoiced. Thank you!!!!!
의 답변
의견 추가하세요
It is quite possible that dirt and corrosion are the source of your problem , not the speaker. Try replacing the dock connector.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Chris Benamati 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 5
지난 7일: 50
지난 30일: 251
전체 시간: 7,498
