주요 콘텐츠로 건너뛰기
Repair manuals and information for the Microsoft Surface line of tablets.
My screen isn't broke but the inside looks cracked.
Screen display is distorted but has cracked image near the magnetic plug site inside the screen.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 12
댓글 달기
답변 2개
선택된 해법
From your description it sounds like you have a crack in the LCD of your touch screen display. The image being distorted is a dead giveaway. With a touch screen display you have two major parts that make a touch screen function. The digitizer is a thin transparent sheet that is adhered to the outermost sheet of glass with a transparent conductive adhesive. The digitizer is responsible for sensing touch on the screen. The second part of the display is the LCD which sits under the digitizer and is only responsible for displaying the image on the screen. So if the image is distorted or not displayed correctly than the LCD in the display is at fault.
So you will need to replace the LCD in the display to fix a distorted screen. If touch is also not functioning correctly then a new display assembly (digitizer/LCD) would be needed.
이 답변이 도움이 되었나요?
점수 13
댓글 5개:
How do we replace the LCD or the display assembly ?
What model of the Microsoft surface do you have? I noticed there are many instructional videos on YouTube for various models of the Microsoft surface. So you may check YouTube. If you let me know the model number of your surface I can help try to locate a guide to help.
I tried taking a head part broken inside my head phone piece out but I did something to my phone and my screen wont show anymore right now what can I do about it I need to get my personal stuff off it like contacts and pictures,songs ,memo as notes and my calendaner my email is gregg4827@gmail.com
I've broken the inner screen of my Samsung Galaxy Sky, I don't know if I can afford to get it fixed
My TV is broken not my PC
댓글 달기
The inter screen looks broke outside screen good
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Cristy Andrews 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 29
전체 시간: 53,210
