주요 콘텐츠로 건너뛰기
Released November 2013. 32 GB of Flash Memory. 8GB of RAM. Quad-Core Processor. Identified by model number EGQ307. 7.58 x 4.60 x 0.45 inches. 1080 x 600. 4.5 hours battery life.
16 질문 전체 보기
질문 마감됨
What do I do when only half of my LCD is working?
When my LCD is on only half of the image is showing on the screen.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
It sounds like the cable connection is lose. Either that, or your screen is damaged and needs to be replaced. You should try opening your tablet, and removing the screen. Reattach the screen and make sure all the cables are attached to the motherboard. If the problem persists than you will have to replace the LCD. Try using the guide below.
Ematic EGQ307 Digitizer Replacement
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
가장 유용한 답변
This could be caused by 2 problems.
1. If you replaced the LCD it could be the connectors arent fully plugged in.
2. The LCD is going bad and you need to replace it.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 271
