주요 콘텐츠로 건너뛰기
모델 A1286. 2011년 2월 출시 / 2.0, 2.2, 또는 2.3 GHz 쿼드-코어 Intel Core i7 프로세서
580 질문 전체 보기
Where is the fuse for the backlight?
Where is the backlight fuse on the logic board, mbp powers up fine I hear the startup chimes, fan spinning. But the display screen is black. I connect the mbp to an external (monitor) and it works. I need to locate the fuse and test it. Also need the ID number in case it needs to be replace.
Thanks
Update
Ok I check the contracts 38 39 40 all at 0.03. I know that this is bad. I had also found on the lvd connector some kind of white foreign substance together with a bent contact and that is only the beginning of other issues. Iong story short this logic board is going to the trash bin and try to get a new board.
Thank you everyone who gave some of their free time to assit me. Once again thank you and god bless.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
3 댓글
ramoncastro, in order to help you out it would be beneficial if you could give us the number of your logic board. It should be a 820-XXXX number (possibly 820-2915-A ) and if you add some high res images to your question (front and back) then we could even point it out for you.
What is the history of this laptop? Any liquid spill? When did this happen? Flowing an incident of some sort?
Logic board #661-5852. The problem started when I tear it down(used ifxit guide) to replace the termal paste. No history of any kind of mishap.
댓글 달기
답변 1개
선택된 해법
ramoncastro12, this is just to answer your direct question. the fuse is reference designator F9700 and it is a #amp 32volt fuse. This does not mean that the failed backlight is caused by that fuse. You do want to pay particular attention to contact 38, 39, and 40 on your LCD connector. Make sure that you do not have any shortcircuit anywhere else.
해당 답변은 도움이 되었습니까?
점수 6
3 댓글:
How could I determine if there was a short? I did notice on the LCD black spots on the left corner othe connector.
Check the answers on here
Yes this is exactly what I've searching for couple days, my Macbook Pro 15" A1286 Mid-2010 have backlight problem. when checking with torchlight I can see the image on screen and working fine with external monitor! Thanks for oldturkey03 .. keep it up!
댓글 달기
귀하의 답변을 추가하세요
ramoncastro12 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 31
전체 시간: 4,643
