Crackling noise inside a MacBook Pro when I shake it
Hello, my MacBook Pro sounds like there's something inside when I shake it, it sounds like a piece is moving, but the rare thing is that the sound only appears when it's turned on.
If I move my computer the the left, the thing goes to the left. If I move it to the right, it goes to the right. Up and down too.
It hasn't fallen.
It's a MacBook Pro 13" Late 2011.
Edit: Now it's happening without shaking the computer, just using it. I think it might be a problem with the fan. Any thoughts?
I found this video on the Internet, I think this is what it sounds like:
좋은 질문 입니까?
댓글 7개
You'll need to take the bottom cover off to see whats up here. It could be the fan or a loose screw. Just make sure to shake the system gently as you don't want to over do it and make sure to capture what falls out.
Dan 의
I already did that. I even disconnected the Hard Drive, but I couldn't get to see anything. It might be a loose screw, but I can't see it. Any thoughts?
Luis Cruz 의
Carefully disconnect the fan does that stop it? Don't run it too long without the fan though.
Dan 의
Hmm. How long?
Luis Cruz 의
Watch the video I posted. That's how it sounds.
Luis Cruz 의
댓글 2개 더보기
