Camera out of focus after replacing battery
Hi,
I replaced the battery and everything seems fine except the rear camera can't focus when taking pictures close up (for example, text in a book). I upgraded to IOS 8.4 recently and can't recall if I had this problem before so I am not sure if it is a function of me replacing the battery and something getting damaged or my recent IOS update. The battery works GREAT and I did not remove the screen and pop off the 3 connectors when replacing the battery so I don't know. Does anyone know if replacing a battery could cause a rear camera close-up focus problem? Thanks!
좋은 질문 입니까?
댓글 3개
I opened the iPhone 5 case again and pushed a little on what looked like the rear camera and the close focus worked again for a few seconds, but then when I closed the case starting from the top (near the camera) which is recommended, the camera didn't near focus again. I did this a few times. Any suggestions from the ifixit crowd on what my problem might be?
tfcraigers 의
It seems like you just need to place rear camera into place. Make sure to not be hitting it when closing the phone. The plastic tabs might be hitting the rear camera (right top corner) when you close the phone
Israel 의
YES. I took apart the case again and pushed the spot where the rear camera was attached. SUCCESS! now in focus :)
tfcraigers 의
