Water spillage no backlight, fused fuse?
Hello,
I spilled some water on my Macbook Pro Retina Display 2012 15". I managed to turn it off and dry it for a week in rice. But now when I switched it on, the backlight is dead. If I put a torch right behind the Apple Logo I can see the login screen.
From what I read this means the backlight fuse might be fused. How can I test if this is the case? I'm going to buy a pentalobe screw and a multi tester but how do I know for sure with the multi tester that this is the right case? I'm no capable of changing such a small fuse but I first I'd like to know if my diagnostic is right and then take it to a specialized place to change the fuse.
Thanks!
좋은 질문 입니까?
댓글 1개
Hi,
I very recently bought a 2014 macbook pro retina 15 serial number
C02LPBG2FD56.
I bought it as faulty with no display backlight. The LCD is working as I checked it with a torch through the Apple logo.
I believe it has suffer a small amount of liquid damage as one of the warning indicators is red. One on the other side is still white.
I have tested the F9700 fuse and there is no continuity. For a moment, I thought I had found the fault but I started testing other similar looking components close by the blown fuse. I did not get continuity from some of these other components. Everything looks normal to me but I am no expert.
Bearing in mind that My knowledge at this level, is very hit and miss. Where do I check next after proving the F9700 has blown.
Thanks in advance....ritchy
ritchy 의
