첫 번째 iPhone 모델, Model A1203은 4, 8, 또는 16GB 용량과 알루미늄 뒷면을 가지고 있습니다. 수리를 하려면 상당한 양의 비집기와 납땜을 요구할 수 있습니다.
286 질문 전체 보기
My iPhone not on and dont want charge why?
my iphone not on and dont want charge why ??
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
아이폰 배터리 수리 키트
Only $29.99
Buy Now
아이폰 배터리 수리 키트
Only $29.99
Buy Now
2개의 답변
선택된 해법
will it power up at all? ie if you connect to wall charger, is it recognised by itunes when you connect with usb? if the battery is dead or dying then only wall power will be enough to boot up. if it is recognised in itunes but no screen display then it may be the lcd is the problem and power is getting through-you just can't see it on the screen.
if not recognised by itunes, doesn't power up with wall charge-check battery (something technical with a voltmeter which has been answered in other questions)
also worth checking cables are seated properly particularly dock connector
check dock connector for damage/dirt in bay-might be if you have dropped the phone?
if it's a sudden problem without damage it's most likely an old battery-most likely if it's the original battery.
hope this is of help.
해당 답변은 도움이 되었습니까?
점수 3
댓글:
+good answer
의 답변
The problem is that the program in Aljha stops and does not give any response from the Touch
i need help plz
thanks
의 답변
의견 추가하세요
just hard press from top and bottom at a time while charging. it will sure help.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
mody 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 1,990
