Blown resistor capacitor on the motherboard
Hi. I have a 11" Macbook Air and one of it's motherboard resistors had blow up.
http://s1.postimg.org/g2cffygfz/image.jp...
How to fix it?
Thanks!
좋은 질문 입니까?
How to fix it?
Thanks!
좋은 질문 입니까?
Vilson, that is C7540 which is a 62UF 11V 20% Tantalum - Polymer capacitor in a Case-B2S-1 package. You will have to of course solder the replacement back on. Biggest issue here is why it got damage. usually caused by a short circuit, so you will have to determine the cause of it.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 1,330
댓글 7개
What exact model is your MBA? Give us the last 4 digits of your serial number so we can properly identify your hardware.
oldturkey03 의
This is the serial number:
http://s15.postimg.org/int34ynor/image.j...
Where I can get that capacitor from?
Vilson 의
I'd check with places like Mouser.com or Digikey.com. Of course there are plenty of others. Just a matter of looking around
oldturkey03 의
Nothing in there. No idea where to look for it.
Vilson 의
Check for some with a lightly higher value. You can use some that have higher values, just never lower. A Sanyo 11TJSF62MAIG would be a perfect match. Not easy to find in small quantities. You may have to scrounge on dead circuit boards etc.
oldturkey03 의
댓글 2개 더보기
