주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
Released Spring 2015 RCA 7-in 8GB Adroid 4.2 Tablet
27 질문 전체 보기
How do I get passed security pattern screen ( forgot pattern)
Security issue with pattern screen
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 8
의견 추가하세요
답변 3개
가장 유용한 답변
Try to do a factory reset and let me know if it helps.
Have the tablet powered off first and make sure you have more than 50% charge on the battery. Boot into recovery mode by pressing and holding the volume up and power buttons. At the RCA logo screen, let go of the volume up button and you should next see an android image. Press and hold the power button and tap the volume up button once more and you will be brought to the recovery mode menu. From here, you will need to use your volume up and down buttons to scroll and navigate to the wipe data/factory reset option and use the power button to confirm. When the process is done, go ahead and reboot and your tablet will be set to factory original settings.
해당 답변은 도움이 되었습니까?
점수 4
댓글:
will i lose any of my stuff
의견 추가하세요
There is a reset button on the back. Press that. WARNING!!!!! It will shut down everything so there will be nothing left on it!!!
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
I need help i can't get in mine I don't have any locks it would not even let me swipe up to get in.( sorry if I missed spell a word I'm only 11)
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Bailey Hawkins 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 1,565
