Output channel "B" is not working. Channel "A" is working fine.
How can I repair my Denon model #: PMA - 757?
Update
Please answer my question.
Thank you!
Nathan Blossom
좋은 질문 입니까?
Thank you!
Nathan Blossom
좋은 질문 입니까?
Oldturkey03:
Thank you very much for your advice. Unfortunately, I do not understand any of it because I have never opened the back of an amplifier in my life.
I live near Cleveland, Ohio, and travel frequently to Toledo, Ohio, Columbus, Ohio, and Buffalo, New York.
Do you know of anyone in those cities that can repair my unit?
Thanks again for your help.
Nathan Blossom
해당 답변은 도움이 되었습니까?
I am sorry, but no idea about repairs in that area. You think you could work on your amp?
Nathan Blossom , first off you want to make sure that all the caps are still good. Check for any leakage around the capacitors as well as bulging tops. Than you want to make sure that you clean all pots and switches with some deoxidizer. Double check all connections on the speaker relay. A good visual inspection would be the best start. Also, post some images of what the circuit boards on your Denon look like, with your question.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 347
댓글 2개
what have you checked? do you have the tools to check things out?
oldturkey03 의
No. I am not tech savvy in the least.
Nathan Blossom 의
