주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
질문 마감됨
iPhone 5 no longer powers on or connects after dock replacement.
After replacing the dock of my iPhone, my iPhone 5 can no longer be charged or connected to a computer. It can however, play audio to the headphones and record audio from the microphone, so the cable which connects to the logic board is at least partially working. I have verified that the batter can be charged in another iphone 5. Is there any way I can troubleshoot with a voltmeter to see where the problem is?
I tried replacing this dock with another, and no luck, I have also made sure the cable works as well. I have compared photos of the connector on the logic board itself, and can see no damage, I have some photos here - http://imgur.com/a/Ieqz5
After a little searching, it looks like the IC U2 could be the problem, is there anyway I could verify this?
Thank you for your help.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Most likely sounds like the U2 IC, especially if multiple docks have not changed the issue.
해당 답변은 도움이 되었습니까?
점수 1
댓글 5개:
Is it possible that I could have damaged the U2 IC while replacing the dock? Looking at the location of it, it seems to be nowhere near the area where I was working, and also underneath another part.
No, the U2 IC is the primary problem. The dock flex never was the issue.
Considering charging and connecting working completely before I replaced the dock, I don't see how this is possible
Then why did you replace the dock to begin with?
Because I originally had problems with my headphone jack and microphone.
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 87
