주요 콘텐츠로 건너뛰기
Sony Xperia Z3 Compact released in Sep. 2014.
82 질문 전체 보기
Black Screen, No Boot, LCD is on but nobody's home.
Hi.
I've recently replaced the screen on my Z3 Compact (I've done this a few times before...) but I think this time I've definitely done something wrong.
Symptoms are as follows:
Phone is on, LCD is working (I can only tell this from the backlight being on) but nothing will boot up. I turn the phone on and I don't get a splash screen or boot up noise.
I've tried resetting it using the power button/volume switch but still get nothing
Any Ideas?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 6개
가장 유용한 답변
I had this issue on Sony Xperia Z Ultra once and it was because a component was knocked off. Sometimes when you pry to get the connector off you can also knock off a component. On the picture I have circled the components that if damaged or knocked off would give "No Image" and symptoms similar to what you describe. I would check all the other components around the connector as well and see if you can see any damage.
It could also be a faulty screen. If you try another screen that you know is working obviously that would eliminate it as the problem.
해당 답변은 도움이 되었습니까?
점수 2
댓글 4개:
Thanks - I'll take a look when I get home.
Does this image apply to xperia Z3?
What are these components and what do I do when there is one missing? How can I get a new one?
He miss one component like that on my Z3 and i got no image but a white or black screen. What can i do?
댓글 달기
Hi, I have the same problem with a Z1 compact. The broken screen DOES light up, the new screen shows ONLY backlight.
When I try the new screen on a DIFFERENT Z1 compact, it DOES work.
So it looks like this particular Z1 does not want to work with this new screen.
But what can be the reason? The broken screen works (at least, lights up and shows image), the new one does not. (on this device)
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
You may need to try a new screen, I have had issues with different displays. Some displays have different versions.
I have the same problem with z3. I have removed the screen and attached it again with adhesives as it was coming off. The phone seems to be functional but only the screen does not work. (black background only)
댓글 달기
i have a Z1 with the same problem, cant seem to find a solution
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Same here, but what are these component, resistance that we maybe can jump or another like capacitor ?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
The black screen problem may caused by your z3 compact drop or suffer collided, which makes the flex cable loosen. you can try to disassemble your phone and reconnect the flex cable.
However, if flex cable reconnect can not fix the screen problem, then you should turn to the hardware solution: change a new screen. We provide the original lcd screen for Sony xperia z3 compact. and we provide the repair guide and fix tools to help you replace.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Try pressing your Speakers output, both of them, hard. It is problaby loose because of moisture and heat during severe conditions.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
matt wilson 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 16
전체 시간: 5,048
