주요 콘텐츠로 건너뛰기
Samsung Galaxy S3는 안구-추적 기능, 늘어난 저장 용량 및 무선 충전 옵션을 갖춘 멀티-터치, 슬레이트-형식 스마트폰입니다.
459 질문 전체 보기
질문 마감됨
Is motherboard from Galaxy S III neo compatible?
My Galaxy S3 dropped on the ground after that the sounds comin from phone were so ugly : ( i tried to change only the speaker but no success. So i have to change the motherboard and i`m askin is it possible to take motherboard from Galaxy S 3 Neo which is absoliutely the same phone with some better specs or i have to put motherboard from S3?
Thank you for your response... : )
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
for things like this specs do not matter what matters is the layout of the board. short answer is probably going to be a no. long answer you would need to look at the boards physical size from every direction including the height of the components, the look at how the components are arranged. you will then have to make sure that your carrier will support the new guts of the device as well.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Ok man thanks for the response.. so i better do not do any experiments : )
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 206
