주요 콘텐츠로 건너뛰기
Released on November 22, 2005, the Xbox 360 wireless controller is the primary game controller for the Microsoft's Xbox 360 home video game console.
89 질문 전체 보기
Why is my Xbox 360 PC wireless controller stuck on player 2?
my Xbox 360 PC wireless controller is stuck on player 2, sometimes player 3. It used to be on player 1 , but now I cant use it, I checked drivers, removed some usb drivers, checked device and printers... but still it displays the player 2 light. :(
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 4개
선택된 해법
I solved the same issue, at least for me. If you have any game streaming service (Such as Kinoi Streamer or the like) Remove it!!! That auto assigns itself to player 1, thus defaulting your controller to player 2! I Uninstalled it, and my controller defaulted to player 1 again!
해당 답변은 도움이 되었습니까?
점수 23
13 댓글:
Yup, that's what it was for me. You rock man.
That was exactly it! Thanks dude!
i tried doing the drivers thing for about a week straight and was baffled, i wish i had found this answer sooner. it worked pretty much /instantly/
yes that what is was for me thanks you nicky ! :d
Wow! Thanks man!
8에 댓글 더 나타내기
댓글 달기
Carlos Daniel, I'd start by trying to resync the controller. Check on here Should it still do this after, try a different controller. This will determine if the controller is sending wrong signals or the receiver board is failing. some of it will depend on which version Windows you are using.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
I guess another wire controller is connected to your PC. It is defined as player 1. That's why your controller stuck on player 2.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Did not work.
Windows 10, all game controllers default to player 2.
Tried restarting,
uplugging and restarting,
deleting drivers and restarting,
removing al streaming software, deleting drivers, and restarting,
still the controller will not work.
해당 답변은 도움이 되었습니까?
점수 0
2 댓글:
Ok, it does work, it just doesn't look like it would.
The player two LED lights up, but when I turn on a game it allows me to play it with the controller.
I guess as long as I don't look at my mouse while the game is on, I should be fine.
Thanks guys.
댓글 달기
귀하의 답변을 추가하세요
Carlos Daniel 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 11
30일 전: 54
전체 시간: 48,173
