15.6" Windows 7 laptop with aluminum surfaces and IceCool technology.
11 질문 전체 보기
How to replace audio jack port?
My laptop's Audio jack port not working properly. I have checked all the necessary settings/ drivers. Its the hardware that needs to be replaced.
Laptop Model: ASUS K53
How can I replace the hardware?
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
1개의 답변
가장 유용한 답변
Here is a link to the breakdown of the laptop, Asus K53E-MT1 Motherboard Replacement that headphone jack is on that separate board with the USB ports on the right hand side apart from the motherboard, which is good news. The hard part about this repair however is going to be sourcing that part to replace it.
I've got the same laptop, Its always been a good machine for what I do with it except I had to replace the charge port connector once but thats a common issue not just with that model laptop, but all of the laptops with that connector. You might have a look at the center pin while you've already got it torn down, thats where they always break and sometimes can be "repaired" by adding solder to support it. Its not a correct fix but a get-by if it's started to crack
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
귀하의 답변을 추가하십시오
Sukumar maji 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 12
전체 시간: 1,131
