Replacement Digitizer not working
Hi - I have an apple Watch 42mm with glass that is cracked all the way round the display. I have separated the Apple Watch display (LED / OLED) from the digitizer and glass, cleaned and all works well. However When I use a new Glass and digitizer it does not work. If i put the original cracked (Apple OEM) glass and digitizer back on it works fine. I thought it was a faulty digitizer so I ordered another one but the same thing happens. Any suggestions?
좋은 질문 입니까?
댓글 5개
Yes i would like to know how you seperated and also if these digitizer replacemnets will work? how did you join the digitizer back to the LCD?
in my experience in ipad repairs, when the digitizer does not work properly, its a damaged ribbon cable. You may be damaging the ribbon cable or you may need to ground the digitizer some how like how you put kapton tape around the edge of the ipad
Kiwi phone repairs 의
Hello! We have the same problem. We try connect about 10 digitizers from different suppliers. They all none work. When we connect original glass it work fine. Did you find some decision of this problem? Did you try to restore firmware after replace digitizer? Thank you!
korsunav 의
Hello,
Same problem with i tied about 5 digitizers none of them worked !
were you able to find out whats the issue . . . ?
Varun Gargi 의
Hello,
I was also able to seperate the LCD and digitizer from my cracked apple watch.
After replacing the digitizer which i ordered from ebay, the watch didn't responding to any touch gestures.
I ordered and tried another digitizer, same result no response to the touch.
I did a lot of reading and concluded that the chip AD7166 which is present on the flex cable is a programmable chip. The chip which is soldered on the digitizers sold on ebay or other websites are not programmed.
Hence they don't work.
Varun Gargi 의
So all aftermarket digitizers are useless? Will trying a complete digitizer and LCD unit even work?
stephenfay1990 의
