주요 콘텐츠로 건너뛰기
The Nyx Noba version runs on Android 4.1.2 Jelly Bean , has a 1 GHz processor speed 512 MB ​​RAM, 4 GB internal memory for all our files and apps, others have a slot for microSD up to 32 GB, and includes a 4GB microSD card.
1 질문 전체 보기
The flash of a Nyx Noba cellphone is always turned on.
Hello.
I have a cellphone Nyx model "noba" which his flash doesn't turn off. I mean the flash always is turned on, even when the cellphone is turned off. The only way to turn off the flash is removing the battery from the cellphone. Is this a problem related to hardware or software? And how it can be fixed?. I hope someone can help me. Thanks.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Disassemble the phone and look for a possible corrosion and shorts. Most of the flash "always turn on" problem occurs when parts shorts with the other component.
Or it you may want to look at your apps (i.e. flashlight,dimmer,bulbon,etc.) it might be in the "turn on" mode operation stucked into it.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Thanks. I'll try it.
댓글 달기
귀하의 답변을 추가하세요
Gerardo Hernandez Molina 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 32
전체 시간: 323
