주요 콘텐츠로 건너뛰기
The third iteration of the 10.1 inch Galaxy Tab tablet.
126 질문 전체 보기
Replaced the usb port but still not working.
I ordered the correct piece and replaced. However, It is not charging.
So did I do something wrong? Can I test it somehow? Or is the battery not charging because I waited 2 months to replace the usb port?
Any help would be appreciated.
Tricia
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개:
I still have the same problem after having the charging port replaced and tested by a professional. My tablet has caused 4 micro usb charging cords to malfunction. Is there a problem with my motherboard or something, and can it be repaired?
댓글 달기
답변 1개
That could be a defective charging port. It sounds like an accident ready to happen. Something must be wrong with the power rails causing a short somewhere. If you feel lucky then you could try a new charging port again and se if it helps. However, I would suggest that you take it to someone who can measure the power rails on the motherboard.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
tricia 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 181
