메인 콘텐츠로 스킵하기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4762 질문 전체 보기
replacement battery discharge faster than original
hi,
my original battery discharge very fast so I decided to change it by a remplacement kit fom ifixit yesterday.
today this battery discharged faster than the original ! do I have to do some charge/discharge cycles to let the battery calibrate itself or does I have another problem ?
also, I eared about the charging method : fast charge will goes to faster discharge and so on with slow charge (with usb for example). what do you think about this ?
thanks guys
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
How long are you considering a fast discharge and what are you doing with the phone? watching video ,playing games , cruising the web. how quick does it discharge if its only on standby and not used for anything else
의 답변
Another thought did you remove the insulation tape from the phone if there's not tape on thew metal case backing against the batery it could be shorting itself out
의 답변
10% loss in one night, 3% in 15 min where I just lunched spotify to synchronize a playlist locally (open synchronize, close) and I use regulary facebook tweetbot to check news so yes videos some time, iMessage etc, normal utilization i think
I lost 2% writing this email through chrome for example so since I'm awake (30 min) I lost 15% of battery
의 답변
Some fresh stats
Ios9 upgrade last night by backup / restore, full charge (usb) then go to bed
10% loss when awake
Utilization last 9 hours :
Facebook : 1 mn on screen, 6h backgroud - 50%
Chrome : 14 on screen - 26%
Spotify : 1 mn - 2 min - 17%
Maybe there is a bug : 5h57 utilisation - 6h58 locked ("veille" in french, I don't remeber how to translate) so 1h of utilisation since last full charge
의 답변
81% left now
With original battery i got 10% left at the end of the day, yesterday shutdown 1h before leaving work
의 답변
의견 추가하세요
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
3개의 답변
선택된 해법
ok guys, some charge / discharge cycles made the battery works great. thanks
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
가장 유용한 답변
Bad luck. Try the service centre
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
thanks, I'm waiting for couple of charge / discharge cycles, maybe the battery need it to calibrate
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
fabienpoyer 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 168
