replace microwave door on model 721
how do i replace the door on microwave model 721
좋은 질문 입니까?
좋은 질문 입니까?
Pat, please remember that door repairs and adjustments, can cause microwave leakage. So please know that a microwave shielding leakage test should be performed for any door repair. G. REMOVING DOOR (Figure 18)
(1) Remove the vent grille by two screws securing it to the outcase loosening.
(2) Lift up and draw the door.
NOTES:
•After replacing the door, be sure to check that the primary interlock switch, the secondary interlock
switch and the interlock monitor switch is in good operating normally.
•After replacing the door, check for microwave energy leakage with a survey meter. Microwave energy
leakage must be below the limit of 5mW/cm2. (With a 275 ml water load)
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 1,622
댓글 1개
Pat, what is your complete model number i.e.721-XXXXXXX
oldturkey03 의
