주요 콘텐츠로 건너뛰기
Nikon Coolpix 7900, 7.1 Megapixels, 3x optical zoom, In-Camera Red-Eye Fix, 2.0 in LCD
2 질문 전체 보기
Battery door won't stay closed
Battery compartment door won't stay closed...Currently I have a piece of tape, it works but.......
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 1개
i have a coolpix p 60 the battery door tab is broken that could be your problum . i would like to find a repiar shop or a new door. rnavaughn@att.net
댓글 달기
답변 2개
가장 유용한 답변
They all end up that way in the end, and I've searched in vain for about 10 years for an answer, but there doesn't seem to be one - it's a design fault, so black sticky tape I'm afraid...
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Put a thin strip of card in alongside the battery as you insert it ,so that it's a good tight fit. I've been using mine like that for ages without problem.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
You're a hero, man!!! When I used tape, I tried A LOT of different ones, none of it worked, it always popped back up. This though is amazing. It removes the upward pressure toward the door and combining it with tape, it doesn't pop back up! I do however recommend using electrical tape on the piece of card so it doesn't burn or something similar.
댓글 달기
귀하의 답변을 추가하세요
mcflymartin40 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 31
전체 시간: 870
