주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 5.5” 스크린 iPhone은 iPhone 6의 큰 버전입니다.
1525 질문 전체 보기
Touch screen unresponsive when touched but 100% visible
I replaced the screen on my gold 6 plus, I decided to put a black screen on Iit and everything went well until I turned the phone on and the screen was unresponsive to touch. Before complete installation I did test the screen and it worked . The screen has light lines running down the screen please help
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Does the home button work?
I didn't attach the home button backing plate yet because I have a stripped screw and ordered a new plate, but the touch id was still funtioning
댓글 달기
답변 4개
선택된 답변
I would take the phone apart again and get it to were it worked before then re assemble slowly and with care checking when possible if it works to know when things go wrong.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
가장 유용한 답변
Sounds like the digitizer flex cable or socket on the board may be damaged. I would inspect those areas under a microscope.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Could also be a short , did you put all the insulating tape back on?
When I extend the flex cable while it's plugged in the screen becomes clearer, but still lines going through
댓글 달기
Your digitizer flex isnt properly plugged in most likely.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
댓글 달기
Touch input all jacked up after multiple screen replacement attempts
^Try this.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Josh B 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 4
전체 시간: 332
