주요 콘텐츠로 건너뛰기
2013년 9월 25일에 발표된 Samsung Galaxy Note phablet 시리즈 3 세대. 모델 번호 N9005로 식별 가능.
248 질문 전체 보기
Replacing Display on Samsung Galaxy Note 3
Can I replace the Front Glass from the LCD display using the iOpener? Some blogs suggest replacing the full display. Posted videos show the Front glass removal using a heat gun or some other forms of heat. The iFixit guide for the Samsung Galaxy Note II provides instruction for replacing the front panel display assembly as a whole.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Like every Samsung glass it can be replaced with some skill and patience.
Honestly, I wouldn't recommend attempting it. It's going to cost you a fortune to fix if you fail and break the AMOLED display.
Definitely don't use an iOpener. If you're going to attempt it you need a heat gun and playing cards at least.
Here's a few tips if you do decide to attempt it:
- If the card isn't cutting through the glue easily then the glue isn't hot enough.
- Don't exceed 90 degrees C. Keep the heat constantly moving and not fixed on one position or you will burn the polarizer.
- Don't cut in from the sides/top with anything sharp or risk cutting the polarizer.
Removing the glass is the easy part, the hard part is putting the new glass on and making sure glue doesn't leak anywhere else.
I'd suggest removing everything from the frame so you can clean the excess glue.
Good luck
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Serveitup 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 171
