Where is horn located
Where is horn located on a 2003 chevy cavalier
좋은 질문 입니까?
Have someone blow it and follow the sound. If it doesnt work and your looking to fix it the horn itself is probably the last thing that goes wrong . Check your fuses and as is with most horn problems check the pressure pad in the steering wheel. this is the most common problem with horns.
해당 답변은 도움이 되었습니까?
jtorres12396, you will find the horn on the bottom right front under the fender
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 2,506
