engaging handle is stuck and will not go up to engage blades
try to raise handle to engage blades but will not move , mower runs but blades will not engage
좋은 질문 입니까?
좋은 질문 입니까?
Is the blade engaged by magnetic switch or by belt clutch. If its by magnetic switch check to see that there's power getting to the switch . If its engaged by belts check to see if the belt is moving when you move the lever or if the lever mechanism is broke .Check the belt has it come off?
해당 답변은 도움이 되었습니까?
the belt looks on but is loose
해당 답변은 도움이 되었습니까?
Not loose piece that is plastic on end of handle is broke
24 시간 전: 3
7일 전: 23
30일 전: 56
전체 시간: 5,510
