phone got wet how do I get it to work again
좋은 질문 입니까?
좋은 질문 입니까?
betty brown, you will have to clean it just like any other phone. Skip any thought (or anything you may have read)you have had about using rice :-). It does not do anything other than give you a false sense of security. You do not want try to restart the phone. This may further damage your phone. The next thing to do is to clean it. Disassemble your phone using this guide Then clean it with +90% isopropyl alcohol. Follow this guide, and even so it was written for a 3G all the points are still pertinent to your phone. While you clean your board, check for any obvious damage, like burned or missing components etc. When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Once all this is done, reassemble your phone and reevaluate. Water damage is the hardest to diagnose since virtually any pat may have failed. Even with all the steps above, there is still a chance that your phone is irrepairable. Hope this helps, good luck.
안내서
난이도:
어려움
1 - 2 hours
안내서
난이도:
어려움
30 minutes - 1 hour
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 55
