주요 콘텐츠로 건너뛰기
모델 A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 또는 2.8 GHz Core i7 프로세서
432 질문 전체 보기
How reconnect display date cable?
When reconnecting the display data cable to the logic board on an EMC 2428, is there a trick to lining it up correctly? I assume that the connection is made by inserting the male cable to the female socket on the logic board by sliding it towards the top of the machine (the reverse of the disconnection), yes?. But I cannot get it to seat in the socket. I would hate to damage it.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 1개
가장 유용한 답변
The only issue one faces is putting the plug in backwards. You may want to take some colored tape to mark across the connector & cable to help remind you which face is outwards.
The alignment is straight in and the wire bail holds the connection.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
dickson 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 271
