screen broke from the inside can I fix it
My tablet got crack from the inside can it be fixed. Some one please help
좋은 질문 입니까?
좋은 질문 입니까?
patty abarca, from what you are describing it sounds like a broken LCD but intact digitizer. It will help if you post some images of what you see with your question. Use this guide to do so. The LCD's are readily available at places like this and many others. There are no repair guides out, so I would suggest that you check check on here as well as on here for similarities. When you do decide to work on it, [URL|make] create a guide so we can all learn from it.
안내서
난이도:
아주 쉬움
2 - 5 minutes
안내서
난이도:
어려움
30 - 40 minutes
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 374
댓글 2개
does the tablet still work?
Power on can you see the screen and does it respond to touch
Jimfixer 의
It turns on but all u can see is liqud. No it does not respond to touch
Lewis Jones 의
