주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3531 질문 전체 보기
질문 마감됨
How to fix brightness control issue after water damage?
I have had water damage on my iphone 5s and the screen stopped working. Since then, I have cleaned the iphone 5s completely with recommended alcohol and thoroughly dried the components. I have also replaced the LCD screen. Mostly everything is working as normal but I cannot adjust the screen brightness (The screen is little dim and difficult to see in daylight). Any recommendations on what the issue could be and how to fix it?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Dim backlight is a tough problem. It is not likely the connectors, more likely corrosion on the display PMU or backlight driver which on the 5s is on the bottom of the board under the air holes in the shield. Once I've seen corrosion on the backlight coil cause dim backlight after water damage--but the coil is fairly well protected in the 5s. Cleaning a board without removing the soldered on shields is the same as doing nothing.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Unfortunately, that's a logic board task. The connector is a ZIF connector, and ZIF connectors are known for not properly connecting on the first try. Try reseating the ZIF display connector. If that does not fix it, then it is definitely the logic board, and you would have to find a new logic board or a new iPhone. Logic boards can be found here: [연계 제품이 누락 또는 비활성화 됨: IF124-028]. Make sure that you pick up the one for your carrier. Transfer the SIM card over using the SIM Card Eject Tool (SIM Card Eject Tool).
SIM Card Eject Tool 이미지
상품
SIM Card Eject Tool
$2.99
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 2,109
