주요 콘텐츠로 건너뛰기
2.16 또는 2.33 GHz Core 2 Duo 프로세서
268 질문 전체 보기
Why doesn't my power cable light green and properly charge battery?
About a year or more ago I noticed that the little light on my magnetic charging cable no longer lit up when attached to the computer.
When I jiggle it, it will eventually light up and show either green or orange (depending on how much of a charge it needs). However, it will very shortly go dim (and sometimes go totally out) and sometimes it doesn't charge my battery.
This has caused the lifespan of two different brand new Apple laptop batteries to be very short. I've cleaned the connector area of all particles and looked all over on the web for what to do about this, to no avail.
Can I replace the "charging port" on my laptop? If so, how do I do that and where can I buy that part? I have already tried replacing both the battery itself and also the charger. Both were official Apple parts purchased from the Apple Store and neither option has helped with this charging problem.
Please help.
Sincerely,
Edwin
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
After checking the AC adapter pins with a toothpick to make sure they are extending, I would replace the left I/O board. Here's the part: MacBook Pro 15" (Model A1211) Left I/O Board
Here's how to replace it: MacBook Pro 15" Core 2 Duo Model A1211 Left I/O Board Replacement
MacBook Pro 15" (Model A1211) Left I/O Board 이미지
상품
$29.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
Thanks!
I checked the pins, and they look okay.
I'll order a new I/O board and hopefully that'll be all I need.
Appreciate the help!
I'll let you know how it goes.
-EA
hi Edwin !did you replace the i/o board ?
does ist work ?
댓글 달기
귀하의 답변을 추가하세요
Edwin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 2,630
