주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Xperia Z3 Compact released in Sep. 2014.
How do I unblock my phone if I forgot my password?
my phone is stuck at the password and i cant seem to remember what it is, any advice?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 84
댓글 40개
Yeah same, mine is a Sony Xperia Z1. I can't find anything to hard reset that without logging in, but I might of found one for the Z3:
1. Power your phone off
2. Hold volume down and the power button until the sony screen shows
3. Release
4. With the recovery screen showing, use the volume keys to scroll
5. Select 'Factory Data Reset' and use the power button to select
6. Select yes and wait
If I am wrong go to here:
https://www.verizonwireless.com/support/...
Yes it is Z3v but I'm not sure if it's different, it shouldn't be but I hope it helps.
but what if its not working what can i do coz have tried holding the power button and volume down nothing is coming to show in that case what should i do
Same problem I've tried the volume down and power nothing happens so what now
I don't want to factory data reset my phone as I want to lose my photos and music I have the Sony Xperia Z3
how do i factory reset my xperia z v1.0 becuase i forgot my passowrd
댓글 35개 더보기
댓글 달기
답변 5개
선택된 해법
Hello Daniel Stott,
Simply you can enter to recovery mode by fallowing instuctions,
  • Power off your device.
  • Boot in recovery mode by pressing and holding Volume Up and Power Button at the same time.
  • Release all buttons when the Sony Xperia Z3 Compact screen flickers and in a few seconds the Recovery screen will appear.
  • factory reset your phone ( use volume keys to navigate)
  • reboot phone
Now you are free to use your phone back
Note: All data will be lost
이 답변이 도움이 되었나요?
점수 14
댓글 10개:
i tried doing that but my phone will not go into recovery screen
that is also my problem its not going to recovery
Same here its not going into recovery screen
What do I do if I don't want to lose any info on the phone
try program dr. fone on a computer, when you connect your PC with your cellphone with USB
댓글 5개 더보기
댓글 달기
Sometimes google with offer reset option on lockscreen after few failed attempts, if not, hacking the password is only option other than full wipe restore, and I'm pretty sure hacking is out the question if on any current version of android.
이 답변이 도움이 되었나요?
점수 4
댓글 1개:
how do you hack it?
댓글 달기
Folow the steps in the video and it will work just fine i just unlocked my xperia z3 android 6.01
https://developer.sonymobile.com/unlockb...
ps:
For the imei of the phone you can log in in to the guest user of the phone open the diler and tap *#06#
Also you need to unlock developer mode you do that using the same guest acount go to setings-about phone-build number and click on that 7 times
The proces will erase all the user data on the phone so be sure to back up your data
이 답변이 도움이 되었나요?
점수 1
댓글 달기
try hardreset your device SONY Xperia Z3 Compact Hard Reset – Factory Reset
이 답변이 도움이 되었나요?
점수 1
댓글 달기
i have a j2pure android phone i am locked out because i cant remember password
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Did you try any of the above answers?
댓글 달기
답변을 추가하세요
Daniel Stott 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 46
지난 30일: 134
전체 시간: 175,754
