주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
mother board repair, water damage
Water damage limited to top of the phone; no signs of any water under the top 5 sockets. there was a bunch of corrosion up there but I cleaned it with non-sweeping ultrasonic cleaner. I'm newbie for soldering but assembling the needed tools for this. the extent of my soldering knowledge is from the recent ifixit videos with Jenna. I could use some expert eyes on this to determine what I need to do; parts I will need. Or practical advice that should send in for repair and learn on some other boards. Phone seems fully functional except for the lcd, digitizer, and likely the two camera sockets. I was able to restore fully to iOS 9.0.2. getting into recovery mode (with use of the home button) and iTunes.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
The camera socket seems to have 1 pin completely burned out, clean again. And I still see some residual damage on other connectors.
Also I recommend flipping the board over, peel off the top shielding sticker to see the water damage below. Touch panel, home button and LCD backlight have relatively high voltage inside the phone, for this reason the chips and connectors are very likely to have water damage around them.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Pictures of the Back
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Breadman 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 381
