주요 콘텐츠로 건너뛰기
The HTC EVO is a Smartphone by HTC powered by a 1-GHz Snapdragon processor and runs the Android operating system.
71 질문 전체 보기
Can I replace the inner case of my Evo?
I dropped my Evo from my lap unto the ashpalt a day after purchasing. The result is three noticeable nicks. I'd like to purchase and then interchange inner cases.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
its possible to change it if you can get the case. Id imagine you can purchase one online somewhere. To change it all you would have to do is take the battery out and unscrew all the screws that holds the case together. Make sure to know where all the screws came from. Also be very careful when taking the case off as there should be some type of tape or something that hooks from the inside to the case to see if it has been tampered with(a lot of electronics have something like this). There is a guide on here that you can follow to take apart the evo. If the scratches are small i would suggest to just leave them as its no really gonna matter in the long run.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Zuniongn 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,955
