Why isn't the fan oscillating?
I've had this fan for over a year without any problems. I tried using i today and the fan is no longer turning as it normally does. It still blows air but doesn't move back and forth. Help!
좋은 질문 입니까?
좋은 질문 입니까?
If the fan isn't oscillating, check that both the remote and front panel are functional to eliminate the chance that the button is simply broken. If this does not help, remove the back casing from the fan. Then, locate any debris or objects that might have gotten into the fan and blocked the oscillation motor. If the fan is still not oscillating, replace the oscillation motor assembly using this guide.
해당 답변은 도움이 되었습니까?
Where can i buy the piece for the turning fan. That piece is broken.
해당 답변은 도움이 되었습니까?
Hi Clara,
It's going to be really hard for us to figure out how to help you with just your description. Can you post a picture of the broken part and where it goes in your fan?
24 시간 전: 1
7일 전: 5
30일 전: 28
전체 시간: 12,656
