주요 콘텐츠로 건너뛰기
모델 A1369, 1.6, 1.7, or 1.8 GHz 프로세서, 64, 128 또는 256GB 플래시 저장공간
Not starting up - 3 beeps on startup
I have a MacBook Air 13-inch, Mid 2011 (1,8 GHz Intel Core i7, Memory 4 GB 1333 MHz DDR3).
The computer is not starting up anymore. When I try to power it up, it beeps three times continuously, takes a short break, and then starts beeping again:
beep beep beep (short break) beep beep beep (short break).... and so on, repeatedly.
What could be wrong with my computer? Is there a way I could repair it on my own?
Thank you very much.
Regards,
Hugo
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
You have a RAM issue. First try reseating your sticks. That failing, try one at a time in each slot to test both the RAM and the slots. Both are known to fail.
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
Thanks for the answer, Mayer. Nevertheless, given that we are talking about a MacBook Air, shouldn't I expect the ram sticks to be soldered to the logic board?
댓글 달기
답변을 추가하세요
Hugo 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 826
