주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
Can't hear callers unless I turn on the speakers!
A week ago I changed the battery of my iPhone 5s. Since then, I can't hear callers anymore unless i activate the speaker. This is not very comfortable, especially if I want to make calls on the road. The front camera is also not working anymore since then.
What I already tried: I thought the earpiece speaker is damaged and replaced it, but still the same problem. What else could it be?
Thanks a lot for your help!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
Good morning!
1 - you checked if you connected all right?
2- If the problem persists, clean well the connection ports .
3 - if anything Previous work for you, you probably are damaged ports on the motherboard and you have to change it!
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
1. Yes, I checked all connections, they are all right connected.
2. I also cleaned the connection ports.
So you think there's a damage on the motherboard? If I'd replace it, I can't use TouchID anymore, alright? Any other possibilities what could be wrong?
댓글 달기
귀하의 답변을 추가하세요
Christof Wittwer 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 102
