주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2686 질문 전체 보기
Glass replacemen for iPhone 6s
Is this different than iphone 6 glass? Lcd still good just need to replace cracked glass. Can't find anywhere that tells me they are same or different
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 2개
Hello,
I would just replace the screen as a whole (with the glass). Theres a higher probability of doing damage to the screen with just trying to replace the glass. Replacing as a whole; the only thing you need to do, is swap some parts over.
Well no one around here can do that repair yet tell me parts not avaliable. Not paying 400$ on ebay for whole display piece. So guess ill pay apple 130$ to fix it at store. Thanks for feed back guys
댓글 달기
답변 3개
가장 유용한 답변
The differences are very minute, but they are not the same product. The 6S Glass panel will be stronger than the 6, to cater to the Force Touch function, so that the screen does not crack.
It is not recommended in any Technicial field to mix and match parts for different models, even if they come across as identical
Regards
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
5/5C/5S glass? or 4/4S? they're interchangeable
The Lenses, yes, but it is not recommended
lol, by whom? The glass is exactly the same strength/thickness etc. They all use the same variation of gorilla glass and the same camera lens. Why is it not recommended? they didn't create 3 different types of glass, there's only one
댓글 달기
@Stephen I don't think so he will buy an glass with same parameters like it is original in i6s
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
OEM iPhone 6S glass is not the same os OEM iPhone 6 glass. You may be able to get away with using 6 glass on a 6S screen but I don't know any professional that would do that.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Kosmo42o 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 802
