Try unplugging it for at least 5 minutes.
Update
You can manually unlock the door by
unplugging the washer
and removing the bottom front service panel as shown in the first image below. Carefully reach up along the inside of the front panel and pull down on the manual release tab that is on the bottom of the door lock assembly. You should then be able to open the washer door.
Normally, the door will not open if the washer does not drain properly. You may find the washer filled with water. The washer will normally signal an error code if it fails to drain and stops with the door locked. It will also signal a fault for most other component failures. If the washer is still full of water, reassemble it and try to run a drain/spin cycle after you remove the clothes. If the cause of the drain failure was excessive suds, then the suds may be dissipated and the washer may drain properly. If the pump will not run, you may have a failed drain pump or a wiring failure. Unplug the washer and remove the bottom front service panel again. Check the wiring connections on the drain pump. If they are okay, then you could have a wiring failure at the control board, a failed drain pump or a bad electronic control board. If the pump runs but will not pump out the water, then you may need to use a wet/dry shop vacuum to remove the water or bail it out. After you remove as much of the water as possible, you can check the large item filter in the pump for a clog. Unplug the washer and remove the bottom front service panel. Arrange towels and/or shallow pans to catch residual water and remove the large item filter as shown in the second image below. You may find a clog in this area. If not, check the drain hose for a clog. If both the large item filter and the drain hose are clear, then you could have a failed drain pump even though it is running.
If the washer is drained when you unlock the door, then you could have a failed door lock or a problem with the water level pressure switch. You could also have a failed electronic control board.
