How do I change the door handle on model PVM1790SR1SS?
How do I replace the door handle on model PVM1790SR1SS oven?
좋은 질문 입니까?
좋은 질문 입니까?
Hi,
Here is a link which shows you an exploded view of the door and also lists the parts. Hope it helps.
해당 답변은 도움이 되었습니까?
Mike Cogozzo you need to remove the "choke" around the inner door. Open the door and locate the plastic seal that goes all the way around the inner door. This is the "choke" and it's clipped in on both the inside and the outside, all the way around the door. You will need to use a small putty knife or a small flat head screw driver and pry under the choke all the way around to unclip it. Once you have that part off, removethe 2 screws going into the door handle.
해당 답변은 도움이 되었습니까?
Since this answer is incomplete, I will add this one point. There are little plastic clips attached to the outer door that hold the grate frame in place. If you look around outer edge of the grate frame with a flashlight you will see them. If you unhook these clips from the grate frame, the grate frame will, not easily, pull away from the outer door and that will expose the handle screws. Be careful, because the grate frame will swing on the door hinges, but there is nothing holding it in place once you unclip it from the outer door so if you let it hang there while you work, it may fall off.
해당 답변은 도움이 되었습니까?
They won't unclip. Is there a trick?
So there are 11 clips that you need to firmly hold down simultaneously. I haven’t the foggiest idea how that’s accomplished without a dozen or so people. And even then, where would they all fit?
Yes there is a trick. Shims. I used coffee stirrer sticks, wish I could post a picture. Plastic zip ties might also work. Used a thin flathead screwdriver to push the plastic clips (twist levering off the metal) and slid a wooden stirrer between the plastic clip and the metal striker. Then lifting the metal corners on the latch end the metal inside door came right out of the plastic outside door revealing the four screws holding the handle. Happy happy. 15 minutes but dextrous people could do it faster.
You can post images in a new "Add your Answer" box on this page.
Write your comment as a "new answer" and then click on the Insert an Image icon in the header bar of the answer box (icon looks like a picture or upside down envelope) and follow the prompts. The image will be placed where the cursor has been positioned in the answer box text so make sure that the cursor hasn't been left in the middle of a word or sentence. I speak from experience ;-)
Before posting the answer it can be previewed to see what it looks like.
Cheers
Moderator
Wow! I did it and I didn't use shims. There were 2 small screws along the top and honestly I don't know whether they had anything to do with how I did this but I removed them anyway. But here s how I got to the handle screws…I JUST PRYED THE GRID TOWARD THE OVEN TILL THE OUTSIDE DOOR CASING FELL OFF! The grid formation stayed attached to the oven on the hinges. The SS door frame and handle fell off and there were the screws! I switched,it out for the new handle then the question was how to get the door trim back on. I closed the grid piece till it latched to the oven. I held the door finish with the new handle lining it up with the black insides and smacked it with my hands and it popped back on the clips.
There was one clip inside that was misaligned after I got it back together so I finagle with it with a butter knife and it's fine!
해당 답변은 도움이 되었습니까?
This was most helpful! I was surprised when the bottom grid popped out so easily. I couldn’t get the top clips to release. I was lucky to have a short Phillips head just the right size. Even though the innermost screw would not fully screw in, everything went back together perfectly!
If you have 8 putty knives to slide under the tabs on the top and bottom then it comes off fairly easy. It only took me an hour to get to that point. I would love to meet the “genius” that designed it!
해당 답변은 도움이 되었습니까?
I used two long metal paint edgers. They slip in between the clips and the frame. Used their leverage to pop the frame and yes, the outside frame will drop off as the hinges are attached to the inner piece.
Why they made this so difficult is beyond me. I inserted a plastic tie between each clip and the grate as I pried the cover away from the clip with a flat head screwdriver. There are 4 clips on top and 4 on the bottom. The plastic ties allow the grate to easily slide out. Make sure someone is holding the door as you do this as the door can easily fall off the hinges.
해당 답변은 도움이 되었습니까?
24 시간 전: 2
7일 전: 5
30일 전: 32
전체 시간: 6,269
댓글 2개
for PVM9179SF1SS door handle replacement .. even after i remove the choke, the screws are under a grate frame .. so not accessible. i tried removed the 3 screws holding the grate frame but still it would not budge. any suggestions ?
Deepak Anchan 의
If it wasn’t for this post, we never would have figured this out. Thanks to all of you!
Kate H 의
