Kenmore elite washing Machine Code error CL, control locked?
How can I unlocked??
좋은 질문 입니까?
Mike, this error code most likely indicates that the CONTROL LOCK has been activated. To deactivate the control lock press and hold the drain and spin button for 5 seconds. Or you can try to reset it by unplugging your machine, and plug it back in after 5-10 min.
해당 답변은 도움이 되었습니까?
Thanks dude...
For the kenmore elite the Cl error was cleared by the stay fresh button. It also says control lock above it
On some models, the control lock is also the chime button. Press and hold that for 5 seconds, and you're good as new.
On my model, Accela-wash, press and hold the extra rinse button which also has control lock on it
Holding the chime button for 5 seconds worked for me! Thank you! :)
해당 답변은 도움이 되었습니까?
If you look closely under the printed word "Chime" is says in VERY SMALL letters/words "Control Lock" Wheewww - thought I was gonna have to call for expensive service :(
Thanks! Holding the control lock button for 5 seconds helped me! Saved me $80 for a service call!
It worked by holding extra rinse
Thanks Mike holding the chime button for 5 seconds worked!!!!
Worked on my Kenmore Elite!! Just press and Hold the Chime button for 5 seconds.
Y'all another brand of Kenmore it's the Extra Rinse and that is also your Control Lock/ mecv
해당 답변은 도움이 되었습니까?
We have model number 796 and this worked for it. None of the above---unplugging it, holding chime button, etc., worked. Thank you so much!
The same thing for me.. but on my model I pushed the control lock for about 10 seconds and it finally reset.
On my model, pressing the Chime button, which is also Control Lock (CL) worked like a charm,
해당 답변은 도움이 되었습니까?
24 시간 전: 3
7일 전: 44
30일 전: 214
전체 시간: 45,708
댓글 5개
Thanks you. Holding the rinse button worked.
Jeannette Trapp 의
I tried everything Chime button, unplugged and plugged it back but nothing works. What should I do
Nafisha Mamdani 의
Hi @nafishamamdani,
What is the make and model number of the washer?
jayeff 의
I did the same and it didn't worked for me
Socorro Ramirez 의
@socorroramirez
jayeff 의
