Apple의 MacBook Pro 노트북 라인은 전문가 및 파워유저를 위한 제품입니다. MacBook Pro 라인은 MacBook Pro 13" Unibody, MacBook Pro 15", MacBook Pro 15" Unibody, MacBook Pro 17" 및 MacBook Pro 17"Unibody를 포함합니다.
14321 질문 전체 보기
DVD/CD player does not function after replacing hard drive
I installed a greater capacity hard drive on a friends MacBook Pro.
The drive works perfectly, but the CD/DVD player will now recognize nothing--no CDs nor DVDs.
We don't live in the same country at the moment, so I can't reopen the case to look for the problem.
Any ideas as to the cause? I don't think I touched any other connectors, but perhaps I accidentally did.
Thanks
Stan Kossen
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
1개의 답변
선택된 해법
Go to the system profiler to see if the drive is even seen for a possible disconnect. I would reset the SMC and PRAM. How was the system restored on the new drive?
해당 답변은 도움이 되었습니까?
점수 2
댓글:
Mr Mayer. Thanks for the response. The system was restored with a clean install of Snow Leopard.
의 답변
HOW did you do the clean install? If in target mode, was the processor a G5 or Intel?
의 답변
I think I misled. I clean installed Leopard before I changed the hard drive. I made a SuperDuper clone of the internal hard drive. Then I booted from the SuperDuper clone, and copied that to the internal hard drive.
It is has an Intel processor. Thanks for your interest and input.
Later I changed the internal HD, and it was then that the DVD no longer functioned.
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Stan Kossen 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 1,753
