주요 콘텐츠로 건너뛰기
Third generation Surface Pro tablet, released June 20, 2014.
123 질문 전체 보기
Damaged screen. How do I know which screen version to order?
The title.
damaged screen. the lcd itself look just fine, no dead pixels. but the touch has gone. i saw that lately there's options to buy screens even v1.1, but how do i spot which version i have?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Most Tablets have a serial number on the rear cover. Model number as well, When ever you buy a communicating device check the settings and on "my device" section it should tell you all the numbers for a particular device, Model, serial, other info. hope it helps. If you can get the Digitize'r out it should have a number on the Flat cable, or on the ribbon cable. LJ.
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
Thanks for the answer. to be honest, i don't understand your answer. I know where to find the serial number. But how do i use him to get the digitizer version? I don't want to open the device screen until the screen will arrive. it's too risky, this is very gentle device. tried to look at the computer specs in speccy, didn't find any useful information. someone?
need to remove the digitizer? seems that all physical things that is produced has to have a number of some kind on it? pasted, stamped, somewhere on it?. to ID that part. I took a break.
This reply is not helpful. What is a communicating device?
댓글 달기
귀하의 답변을 추가하세요
dtamish 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 2,269
