주요 콘텐츠로 건너뛰기
2014년 1월에 처음 출시한 Pebble Steel은 Pebble Technology Corporation의 금속-외형 스마트워치입니다.
My Pebble steel isn't vibrating when I receive a new notification
My Pebble Steel watch is not vibrating when I receive a new notification. I can still see when I get a notification because it pops up on the screen but I don't feel the vibration. I have made sure that the settings on my phone and watch are both set to vibrate for a new notification. What else can I do?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 1개
that fixed the problem. thanx.
댓글 달기
답변 6개
선택된 해법
Also, try visiting the troubleshooting page for more help.
이 답변이 도움이 되었나요?
점수 6
댓글 달기
가장 유용한 답변
Mine was in Quiet Mode. You can change this in the settings. You can also change this by holding down the button on the left side of the watch while at the watch face.
이 답변이 도움이 되었나요?
점수 18
댓글 12개:
Worked for me, i feel so stupid now
Mine was not working either, Supid #2! Thanks!!!
Wow! Thanks! *face palm*
Add me to the dummy list! Thanks for the help
Not working. Howwwee
댓글 7개 더보기
댓글 달기
Try resetting the watch.
이 답변이 도움이 되었나요?
점수 3
댓글 3개:
I reset it and it only vibrates on phone calls.
I reset mine nothing, no vibrating at all. I'll try again.
Though it works, feels over kill. Try the quiet mode
댓글 달기
No solution worked. No vibration at all even after hard reset
이 답변이 도움이 되었나요?
점수 1
댓글 달기
My pebble steel started to vibrate again, after android wear app was removed
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
I had same problem after installing Android Wear. I took 'belt and braces' approach and deleted AW app and also did a factory reset on the watch and signed in with a new account to make sure I really was back to 'factory settings'. I chose this boots-and-all approach as I had previously also installed a new watchface (Beacon) which screwed the watrch up completely and caused it to reboot at random times and I wanted to make sure I had totally got rid of it.
Thanks. I m on the top of the dummy list!!
댓글 달기
Just discovered this:
Notifications will appear, but not vibrate, when the Pebble Time is charging.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Orlandria Heggs 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 26
전체 시간: 15,831
