주요 콘텐츠로 건너뛰기
2012년 10월 23일에 출시되었습니다. Core i5 또는 Core i7 프로세서. Apple Fusion 드라이브.
200 질문 전체 보기
How do I create a fusion drive from an SSD and HDD
My Mac Mini late 2012 came with 1 HDD, I installed an SSD drive in the other available drive bay. After rebooting, both drives are available, but I cannot seem to create a combined fusion drive. I tried reinstalling the OS (El Capitan 10.11.1) but it does not create the single fusion drive. The OS installer will only let me install on the one of the two drives.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 해법
Sorry for not getting to you, I needed to do some checking. El Capitan Disk Utility is not as good (complete) as the older Mavericks & Yosemite versions. It appears Apple still won't let you create a Fusion drive with it with 3rd party SSD's.
But don't despair! You still can do it you just need to do it using the command line interface. Follow this: How to make your own Fusion Drive. Be aware you will need to do this from an external bootable drive as you can't do it using the OS on the current drive.
해당 답변은 도움이 되었습니까?
점수 7
댓글 1개:
Thank you Dan, the Terminal method worked. I installed El Capitan and programs and it seems to work well with fast restarts and program startups.
댓글 달기
it didn't work for me. I got: "A problem occurred; undoing all changes Error: -69888: Could't unmount disk"
해당 답변은 도움이 되었습니까?
점수 0
2 댓글:
Sounds like you have a hardware level problem here. Best to create your own question with all of your systems details.
I had exactly the same errors. I solved it by booting from and external hard drive that had the OSX
I then used Terminal to link the internal HD and SSD to create the Fusion drive - and now it finished without errors.
Once done I used remote restore to load the OS onto the Fusion drive. After that it booted to the Fusion drive great.
Problem solved
Hope this helps someone
I made sure the internal HD and the internal ssd were unmounted and then ran
댓글 달기
귀하의 답변을 추가하세요
gretaworcester 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 12,874
