주요 콘텐츠로 건너뛰기
First generation, based on the Ford C1 global platform.
Mazda 3 2004 2.3L eng chk light on code p2228 & p2004.
The engine have problem on idle sometime eng shutdown
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
Danisand, Error code P2228 is Barometric Pressure Sensor A Circuit Low and P2004 is Variable Tumble Shutter Valve Stuck Open
Possible causes
- Faulty VTC Shutter valve actuator (Stuck open)
- Missconnecting or pull out the vacuum hose
- Faulty Variable tumble solenoid valve
- Variable tumble solenoid valve harness is open or shorted
- Variable tumble solenoid valve circuit poor electrical connection
from here. Check your vacuum lines as well as your EGR valve.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
p2228 is a intake sensor error so you may have a plugged air filter or a broken MAP sensor .the p2004 is a intake manifold leak probably a vaccum hose around the intake
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Danisand 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 68
전체 시간: 6,425
