주요 콘텐츠로 건너뛰기
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 질문 전체 보기
iPod hasn't been able to turn on
I opened up my 4th gen iPod to fix a jammed lock/sleep button. I had turned it off before working on it as a safety measure. Now I haven't been able to turn it on. Even if I connect it to iTunes the screen doesn't light up.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개:
I have an ipod touch and for some reason I have left it on charge for hours and then I treyed to turn it on and it wont turn on for no reason
댓글 달기
답변 2개
Hey Kathy,
So iPod TG4's are infamous for being finicky devices, the first thing I would try is to bridge the connection between the metal on the bottom of the charger port to the positive battery terminal. Often times this will bring them back to life. If that does not work let me know and I would be happy to help you further!
PS make sure you scrape off the covering over the solder connection on the battery terminal
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
Is there a more simpler way to solve this problem?
Not that I know of however I have seen many of them come back to life after said reset.
After many a try I could not get it to turn on. Any other suggestions?
댓글 달기
my ipod has that blank screen too but my home button is completely broken..my screen has been like this for two days now and its weird how when i charge it i hear the charge sound i jus dont know what to do to get the thing on
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
kathy 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 6
전체 시간: 160
